Air ride installed...
#882
Now I'm concerned that I will forget this and park with the handlebar forward or to the right and have a unexpected air leak and the bike fall while I'm not there.
where did you find the wedge?
Rick
#883
#884
So after a long day yesterday of fabing up the air ride lines and electrical, I flip the switch and one of the shocks has a hole in it, damn! So I have to send then back in now but I did learn I need longer grade 8 bolts, a few 90* fittings and a smaller switch. My question about the switch is, I have a 2014 so no using the CVO switch, where can I find one that is small enough to fit into one of the holes under the seat in the frame. I have found a few larger sized ones but can handle the amperage and a few smaller ones that say they are good for 6a at 125vac and 3a at 250vac but not sure how that computes in relation to dc. I work with electrical quite often but I am not sure if this switch will suffice for the 12a compressor. Any suggestions?
#885
#886
What did you end up doing for the switch? I am in the same situation seeing that I have a roadking.... I have a large momentary switch that I'm thinking about mounting on the dummy switch where my passing lights are mounted...
#887
So, not trying to hijack the thread but I put an Arnott Air ride on this winter and have had a few short rides on it so far. The thing rides like a hard tail! Doesn't matter if I'm aired up or down or in the middle. The ride is horrible. When I hit the expansion joint on one of the bridges here in town, it pops me right outta the saddle. Anyone else have this problem?
#888
I'm using the Monroe's and there are the same way. You will hear of people saying you need to find the sweet spot, which for me was above the half way point in the travel. But this puts me up in the air like I'm sitting on a 500 dirt bike. This defeats the purpose of installing the air ride system for me because I wanted to drop it and then ride it. But I knew that before I installed it and decided that I would just deal with the rough ride.
The part that I do not like is that you have to decide on the "spot" that you plan on riding it and then adjust the belt tension for the level. That means that anythng other than the "spot" is just for parking lots. Yee Ha!
I was wondering if this was an issue for the kits out there like Shotguns, Legends, Arnot's....... I could not find any mention of the fact that although it has 12 different ride heights, you can only use one without a belt adjustment!
