Another Compensator Question
remove primary and close inspection. what does it do? it smooths out the driveline whip saw effect from a large V twin at the end of the crankshaft as the power is supplied to the chain drive going to your clutch. stock factory compensators are built to handle stock engines. HD didnt put a super duty one in at assembly for your 100 HP build later on.
My stock compensator couldn't handle my stock motor and came apart at just shy of 25,000 miles. I got damn lucky I got it to the dealer when I did, as it was at the point of catastrophic failure.
The symptoms were startup noise, a rattle around 3,000rpm, excessive driveline lash, and terrible clutch engagement from a standstill. The dealer was kind enough to replace it with the S/E part under warranty.
MrSunset
11
09-26-2012 08:57 PM
