iPod interface module, only left speakers working. Help
Did the installation and followed the instructions. All clear and straight forward but when I tested it the left speakers were working (front and back) whilst the right ones.
I did a reverse 19 to 31 and 31 to 19 but nothing changed. All the functions are working well.
Please help me troubleshoot it.
FLTRUSE:
http://
FLHXSE2
http://
Since it's your right side that isn't working, I'd start with the tan/black wire's insertion in the 35 wire connector and be sure that it is fully inserted and locked into place. If you disconnect the plug from the back of the radio, all of the wire terminals (sockets) should be visible immediately behind (touching) the inside of the red lock. If the wire in 31 is different from the rest of the wires (i.e. it's end isn't as close to the red lock as the rest, it's not fully inserted and is not contacting the pin inside the radio's socket. You can also check the other end of the tan/black wire.
If the problem isn't the tan/black wire, I have no other ideas for troubleshooting.
Carl
Hope you find the problem; I hate it when I think I've done everything correctly and the accessory doesn't work as intended.
The first wiring diagram (FLTRUSE) shows the 35 wire connector (28A and 28B beneath the word "Radio") and the wire assignments. The wire in 31 is tan/black and is for "Right Ipod." The same wire color and assignment is shown in the FLHXSE2 diagram at the bottom/center of that diagram.
Let us know how you make out with your troubleshoooting.
Carl
Carl
Problem solved, special thanks to Carl. The Black/Blue into cavity 31 fixed the right speakers.
The following are based on what was given in the instruction paper
Tan/red * * : cavity 8
Violet/gray : cavity 19
Tan/blue * *: cavity 31
Red/blue * *: cavity 4
Black/blue *: cavity 27
And the following setup that worked for me
Tan/blue : cavity 19
Black/blue * *: cavity 31
Violet/gray *: cavity 27
By the way, I tried plugging and unplugging the violet/gray into cavity 27 and found no difference!
Hello all together
I have a 2011 Street Glide and I bought Harley Davidson Boom Audio iPod Interface
But I don´t find the connector 6 B under my Fairing. Is someone here who can help me and give me the information where I can find tis connector.
Many thanks for all information
Jürgen
Jürgen
Thanks again for your answer.
Jürgen
