Cardboard Insert For Brake Lever
I have an 09 Road King Classic. I am changing out handlebars and adding the Chrome Switch housings. Everywhere is a warning to put a cardboard insert between the brake leveer and the brake lever bracket (see attached picture) However, the end of my brake lever isn't flat like the picture but comes to a point. I see no way to put anything in there but don't want to break the switch. I called a local dealer and the service guy wasn't sure what I was talking about. Any help would be appreciated.
I just changed the bars on my 09 Ultra. If you can't get a piece of cardboard in there, yours is different than mine. I just pulled the brake lever to create some space and inserted a fairly thin piece of cardboard. It took a couple of trys to get it thick enough to hold the lever, but thin enought to fit in the space.
jstride, if you look at the instructions for the HD chrome levers for '08 and up models, you'll see how to place the cardboard insert:
http://www.harley-davidson.com/en_US...ts/-J04278.pdf
The picture you posted is of the pre-'08 master cylinder/brake lever; the above link shows the '08 and newer m/c and brake lever.
Carl
Carl
Without that spacer in there holding the brake lever pulled, there is a very good chance of breaking the nipple off the brake light switch. then you've got to replace the brake light switch. That's a PIA job. Also depends on what year bike. HD changed the brake switch setup at some point in time, maybe mid 90's.
