Primary capacity ???????????????????
Look through the derby cover and verify by shining a flashlight down inside that while in the upright position the fluid just covers the bottom of the clutch basket by about 1/4" I don't measure out exact amounts. Just know that you will need to purchase 2 bottles of your favorite fluid and that you will have some left over.
I'd pour in 40 then look with a flashlight. Bike sitting level.
Well...I cheated.
Since it was all coming off I drained the fluid and pull the primary off with the derby still attached. Since I usually dont think ahead I didnt realize that I needed the derby bolts for the new one anyway....duh.
I put 45oz in.
I wanted to reuse that primary gasket soooo bad. It only had about 2k on it and still looked new. But, I used the new one and saved the old one. I did reuse the derby gasket, I have a new one if I need it.
The dealer did the 10k service when they took the bike in on trade. The primary fluid was still clean after about 2k of use. The derby bolts on the other hand. 1 bolt I could turn with my fingers, 3 of them were about right, 1 of them was tough to get off. What, did they have 3 different guys working on the bike?
I did learn today that I need better tools. After 35 years of metrics most of my sae tools are HF or an off brand. Those are ok for alot of jobs but when working on threaded aluminum or next to a $200 chrome piece you dont want a cheap tool to break or slip.
Did HD plan on useing a different size fastner on every single part on my motorcycle or was that just an accident.
Are those grade 8 bolts strong enough to hold the outer primary and derby covers on or do I need to beef them up?
I put 45oz in.
