Hi, I am new to the forum and own a 2007 fuel injected Road King Classic. I removed my detachable windshield for the first time and now it seems the two spring clips that are supposed to help hold the windshield in place are not low enough to drop behind the top rubber bushing (it may have always been that way, but I am not sure). I assume the clips are supposed to drop down behind the bushing to keep the windshield from moving forward and possibly falling off. If this is true, it looks as though these clips need to be bent down so that they will rest in a lower position. Since the owner's manual does not really provide any specifics on the spring clips, I do not want bend the clips until I am sure that is what they are for. Any assistance/input would be appreciated. Thank You Respectfully, Scott
spring clips are for you to hold when removing orreplacingwindshield. set lower into position then put upper into position and push into place, i find the springs helpful when removing but little help to reinstall. hope this helpfull..good luck with king
