What's the best fit "inch equivalent" wrench for the 36mm rear axle nuts?
12-07-2010, 02:59 PM
check your local auto parts for a free rental
12-07-2010, 03:03 PM
only two wheels. the proper socket and wrench was not that costly. and the tourque wrench works on everything. BTW the guage for properly adj the belt is cheap.
12-07-2010, 03:23 PM
Go to HF, those sockets work fine.
As with all tools, use common sense.
Dont put a impact wrench on a socket not designed for one.
Dont stand on a 4ft cheater bar.
12-07-2010, 03:26 PM
I spent less than 10.00 for a Craftsman 36mm
12-07-2010, 03:45 PM
Quote:
Two 12" Crescent Wrenches works fine for me. I tighten by hand which IMO is right at 100 ft. lbs. torque, LOL. Adjust belt so it has 3/8 - 7/16" play works fine also but not by the book so I'm sure some here won't approve. Some of this stuff isn't rocket science.
You posted what I was about to almost word for word!!!! I was laughing at what I was going to type and then read your post. WEIRD man....
12-07-2010, 03:47 PM
axle nut
Quote:
Originally Posted by
barrygreen
1 7/16 is as close as your going to get, use a 6 point socket
Yep, what barrygreen said. 1 7/16 Socket and boxed end.
12-07-2010, 03:59 PM
Thanks everyone. I already have the belt tension tool. The idea of actually using the right tool has some merit, lol.
Still looking for a link to a DIY for the snail cam adjustment procedure.
12-07-2010, 05:32 PM
12-07-2010, 05:47 PM
1 3/8 open end , kissed by the belt sander till it fit.
12-08-2010, 06:57 AM
i use 1 3/8" six point socket...no problems
