What's the best fit "inch equivalent" wrench for the 36mm rear axle nuts?
Old 12-07-2010, 09:28 AM
Dale_K's Avatar
Dale_K
Dale_K is offline
Default What's the best fit "inch equivalent" wrench for the 36mm rear axle nuts?
I've had good luck with "inch" size substitute wrenches in the really big sizes. Tractor Supply Company has them pretty cheap. Which one fits the current generation rear axle nuts? I think they're 36mm metric.
Second question: Is there a good DIY thread with pictures on belt tension procedures for the current generation bikes with the snail cam adjusters?
Old 12-07-2010, 09:50 AM
valvestem's Avatar
valvestem
valvestem is offline
1.417 inches = 36 mm, 1 15/32nds may work
Old 12-07-2010, 09:51 AM
gmc's Avatar
gmc
gmc is offline
Two 12" Crescent Wrenches works fine for me. I tighten by hand which IMO is right at 100 ft. lbs. torque, LOL. Adjust belt so it has 3/8 - 7/16" play works fine also but not by the book so I'm sure some here won't approve. Some of this stuff isn't rocket science.
Old 12-07-2010, 09:53 AM
barrygreen's Avatar
barrygreen
barrygreen is offline
1 7/16 is as close as your going to get, use a 6 point socket
Old 12-07-2010, 10:17 AM
steelpony5555's Avatar
steelpony5555
steelpony5555 is offline
Could probably pick-up the right size at Harbor Freight fairly cheap. Won't be for everyday use, but for occasional use would work fine. If you use it alot then shame on you, call the Snap On man and get the right one. I think Snap-on and Sears even sells sockets individually so you don't have to buy a bunch you don't need. If there's one thing I learned in this life is use the right tool for the right job.
Old 12-07-2010, 10:32 AM
kjelders's Avatar
kjelders
kjelders is offline
Sears sells the 36mm socket by itself
http://www.sears.com/shc/s/p_10153_12605_00944248000P
Old 12-07-2010, 10:49 AM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Neggy ZRXOA 5248 is offline
36 mm is pretty common for CV shaft nuts, so you should be able to pick up a Lisle, Craftsman, or other consumer grade socket for reasonable money, under 20 bucks
http://www.thetoolwarehouse.net/p-3108-lisle-39550.aspx
Old 12-07-2010, 11:11 AM
lp's Avatar
lp
lp is offline
Received 2,719 Likes on 1,545 Posts
I know you're not asking but there is a 36mm wrench in your bike tool kit if you have one...
lp
Old 12-07-2010, 12:31 PM
VETERAN75's Avatar
VETERAN75
VETERAN75 is offline
autozone or advance should have a socket at a decent price. How often would you use a 1 7/16 anyway, just get the 36 and be right.
Old 12-07-2010, 01:09 PM
carpetride's Avatar
carpetride
carpetride is offline
A medium size pipe wrench will work.
Quick Reply: What's the best fit "inch equivalent" wrench for the 36mm rear axle nuts?
