SE Compensator WOES
Old 12-12-2010, 02:52 PM
Feedsack's Avatar
Feedsack
Feedsack is offline
Exclamation SE Compensator WOES
Took apart the SE compensator after finding sparkles in the primary fluid. i am running redline primary
I heard of but cant find a fix for this any one know of one?
Attached Thumbnails SE Compensator WOES-gedc0001.jpg   SE Compensator WOES-gedc0002.jpg
Old 12-12-2010, 03:14 PM
sifularson's Avatar
sifularson
sifularson is offline
Hard to tell from the pictures. Is the metal coming off the inside of the gear? Is there wear on the shoulder of the inner gear?
It looks like things are getting hot in there. What do you think?
Old 12-12-2010, 06:41 PM
dawg's Avatar
dawg
dawg is offline
Received 2,946 Likes on 1,705 Posts
You have what is called fretting. There is metal to metal contact and the oil is not getting to the shaft. rbabos and others have cut grooves into the SE comp. I plan on doing the mod to my SE comp prior to the spring when it comes out of hibernation. Below is a pic of how to do it.
Old 12-12-2010, 06:42 PM
dawg's Avatar
dawg
dawg is offline
We have a several page conversation going on this issue right now on another forum.
Old 12-12-2010, 06:44 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Is it a secret forum?
Old 12-12-2010, 06:50 PM
dawg's Avatar
dawg
dawg is offline
Nope, it's HTT.
Old 12-12-2010, 09:57 PM
hydrolock43's Avatar
hydrolock43
hydrolock43 is offline
Default SE compensator
I saw the exact same rusty looking oil/paste when i just took my 96 out of my Road Glide for a 120R install. Figures that i put the new SE compensator right in that came with the crate motor. The one i saw the rusty looking sht on i just put in during the summer,noticed it when i was taking the primary off for the engine swap. I also had Redline MTL in the primary looks like tranny fluid red tint same stuff they market as primary fluid. Wonder what the long term damage is with this left unattended?
Old 12-13-2010, 06:11 AM
Feedsack's Avatar
Feedsack
Feedsack is offline
Thumbs up Thanks Dawg
As usual, thank you for your help. I thought about the other one after I posted this. Sometimes you just have to keep trying various combinations of words to find what it is your searching for.
Old 12-13-2010, 08:07 AM
HDV-GLIDE's Avatar
HDV-GLIDE
HDV-GLIDE is offline
When is HD going to own up to their screw-ups. First we have to replace the stock comp with the SE version, now we have to modify that ourselves so it doesn't fail. What's wrong with this picture folks.........
Old 12-13-2010, 08:48 AM
voodoodrug's Avatar
voodoodrug
voodoodrug is offline
after installing the se comp last spring I can hear the spring plates chattering a bit when not under load while hiiting the gas. Is that normal? thats the only woe that brings about any concern,but now this mod...hummm interesting
Quick Reply: SE Compensator WOES
