Rev limiter???
RE: Rev limiter???
Has the PCIII changed? Used to, you couldn't alter the REV limiter with it. You had to have a SE download to up the limiter.
On this FAQ page, Dyno Jet says a Power Commander does not raise the rev limiter.
http://www.powercommander.com/suppfaq.shtml
RE: Rev limiter???
Newer PC III have the Rev Xtend built in. It does in fact raise the rev limit 700 rpm to 6200.
If you have an older PC III you can still get the Rev Xtend via a flash.
http://www.powercommander.com/hdRev.shtml
I too have done this to mine and love it. I also added the Accelerator Pump Utility and love it as well.
http://www.powercommander.com/accelpump.shtml
RE: Rev limiter???
ORIGINAL: MrMcCool
DITTO
RE: Rev limiter???
Extended the Rev Limit on my 06 RKC and I will side with the rest of the guys. As for longevitiy, who knows. I am sure if you pound it every time you get on it it will not last. As for me I have ran it up only a few times in the 2 months with it, but knowing it is there, if I want to let the ponies run, is a good feeling.
Semper Fi!
Semper Fi!
RE: Rev limiter???
I dont know how much it helps with a stock cam hp and tq will only fall off after 5000 mine is set @ 6500 with my race tuner and I never hit it I alwayse shift around 6000 @ the most with my cam my tuner set it @6500 before that it was @6200 and I had to try to limit it out but I dont think it will hurt your motor unless you spend a lot of time turning those rpm's.
RE: Rev limiter???
ORIGINAL: td3
I have read about raising the rpm to 6,200. My bike is 5,500 stock. Running the power commander and would like some advice....
As for the Accelerator Pump Utility, well all I can say is its a waste. Get a good tune with the PCIII is all you need, you can add all the fule you need using the PC. My .02 for what its worth
plumb4fun
06-17-2008 10:51 PM
Screamer
11
01-14-2006 12:39 AM
