HD Center Stand
I have it on my '09 Road Glide. I received it last year for Christmas. I love it. (See signature picture)
I had the Chrome Display Stand that was mounted on the front under the Crash Bar. I always had a problem with clearance when in low turns. It would grind the road before the floorboards.
With the new Center Stand, it tucks up under the center and is not seen except for the lever that comes up just in front of the left muffler pipe. I can hardly see it. And when it comes to clearance, it is never problem. I have better clearance with the new frame and can lean over better. I have rubbed the floorboards a couple of times, but Never has the Center Stand came in contact with the ground.
I really love the fact that the end of the stand can be adjusted to make the height of the frame low so the rear wheel is still on the ground. Or the clearance can be set to raise the wheel off the ground, if I wanted to do so.
The only thing I don't have with the Center Stand that I had with the Front Display Stand is that I could use it when I was still on the bike. Now I can only use the stand when I get off of the bike.
There are other stands made by other companies, but, IMO, Harley hit this one out of the park.
I've read umpteen comparisons on center stands and the EZ-Up seems to be the up and away favorite. Do a search on it. I owned one and it's rock solid. The damn thing could probably support a tank.
The problem I have with any center stand on my 09 Road King is that I push it pretty hard through curves and I'm constantly catching the foot board supports - never mind a center stand beneath that. And, no, my bike is not lowered, and it has lifted spring Progressive shocks. The Chinese air shocks that come with these bikes is a sad embarrassment.
To each their own, but I'm not presently into center stands. But if I were, that EZ-Up is hard to beat.
