Removed the catalyst from the head pipes
Old 01-08-2011, 02:15 PM
SpiderPig's Avatar
SpiderPig
SpiderPig is offline
Do not mean to hi jack the thread. But how do you "Gut" the cat out of the head pipe?
Old 01-08-2011, 04:40 PM
badbobby's Avatar
badbobby
badbobby is offline
6th Gear
I read where you can remove the muffler and use a core cutter that is extended but I can't remember what size they used. The only thing I see in the way or the 2-O2 censers that can be removed before drilling.
Old 01-08-2011, 05:14 PM
mfuchs2004's Avatar
mfuchs2004
mfuchs2004 is offline
Originally Posted by Energy-Dude
That's funny! Everytime I do a performance upgrade my mileage goes way down for a couple of months also!!! Lol
That's because most mods affect the accuracy of the throttle position sensors in the rider's master control system.
The fix is well documented on this forum. You just need more mods.
Old 01-08-2011, 07:59 PM
AbnMP13's Avatar
AbnMP13
AbnMP13 is offline
Subscribed
Old 01-08-2011, 10:06 PM
prostar's Avatar
prostar
prostar is offline
Just change from an 09 California Head pipe with cat to a federal pipe no cat and it sounds much better. Will be even better when I get the Rineharts on.
Old 01-09-2011, 08:51 AM
badbobby's Avatar
badbobby
badbobby is offline
6th Gear
Unhappy
I think that's what I might end up doing if I can't get my answer.
Old 01-10-2011, 05:27 PM
Meatloaf-sc's Avatar
Meatloaf-sc
Meatloaf-sc is offline
I cut mine in half in the middle of the cat, chizled it out and welded it back together, works just fine and cuts the heat way down. Put some older SE slipons (ebay 50$) on and it sound great , way better than droping a grand on a whole new setup.
Old 01-10-2011, 06:57 PM
stewy1200c's Avatar
stewy1200c
stewy1200c is offline
The best way is to take the head pipe off the bike, (Or buy a take-off from e-bay or the classifieds here). cut the pipe in the center of the cat. I used a horizontal ban saw we have at work. Thats where I'm at right now. (not my pic but this is what it will look like) Tomorrow I'm going to use a sawz-all and cut around the "guts" and pull them out. My Indy is going to tig weld it back together Friday.
Attached Thumbnails Removed the catalyst from the head pipes-cat-on-a-2010.jpg
Old 01-11-2011, 12:25 AM
Toocold's Avatar
Toocold
Toocold is offline
What do you do with the 02 sensor?
Old 01-11-2011, 02:44 AM
Lonewolf176's Avatar
Lonewolf176
Lonewolf176 is offline
Just remove them before gutting the cat. With the '10's I would be concerned about reversion causing "cross talk" between them. The '09's they are in a different location.
Quick Reply: Removed the catalyst from the head pipes
