Backwards front rotor?
Old 01-06-2011, 09:31 AM
shore's Avatar
shore
shore is offline
Default Backwards front rotor?
I'm putting an 18" '11 streetglide front wheel and tire on my 07 FLHT. All Is well. Bought a $85 flush mount 08-up axle and it fits.
The question I have is the rotors. I was pulling the rotors off my 07 wheel and taking note of the direction on them versus the direction of the tire. The right side marked rotor is on the left. . This is a 100% stock harley. The bolts have never been cracked.
It's not like it's a big deal but here is what I'm thinking. I'd put them on the correct side but what about brake pad wear. The pads have worn the rotor a particular direction. Flipping the rotor around will sure have an edge IMO>
I don't know...what say you guys?
maybe the rotors are supposed to be backwards. The direction of the vanes goes with what is marked on the rotors.
Old 01-06-2011, 09:35 AM
Lonewolf176's Avatar
Lonewolf176
Lonewolf176 is offline
If I remember correctly they were reversed to stop the squeal.
Old 01-06-2011, 09:40 AM
shore's Avatar
shore
shore is offline
I'll put them back like they where.
My handy dandy previous C4 Targa Top Tool came into use on those bolts. I haven't used that tool in 8 yrs.
Old 01-06-2011, 09:41 AM
DPete's Avatar
DPete
DPete is offline
Big Kahuna HDF Member
Received 1,729 Likes on 1,302 Posts
Mine are reversed from the factory
Old 01-06-2011, 09:57 AM
shore's Avatar
shore
shore is offline
Oh and talk about something tough, getting that flush mount axle nut to seat...wow is that tight. I'm using a 1/2" ratchet and it took some serious force to get that to pull into the right for leg. It's nearly flush,sheet of paper away but i'm afraid it's going to snap. Naturally, it the bolt goes in and out easily it's just pulling it in the axle that's a bear. I tried persuading it with a hammer and tape but all that did was put a mark on it....Oops. I can polish that out.
Old 01-06-2011, 10:05 AM
RaceFace's Avatar
RaceFace
RaceFace is offline
I did some research on them a while ago and that's what I saw too. Harleys answer to noisy brakes
Old 01-06-2011, 10:29 PM
skratch's Avatar
skratch
skratch is offline
Received 4,179 Likes on 2,450 Posts
if it worked, whats the problem? btw, it did work on my 07.
Old 01-06-2011, 11:17 PM
BackAt5O's Avatar
BackAt5O
BackAt5O is offline
The 07 service manual will tell you to put the disc marked right on the left side and the disc marked left on the right side.
Old 01-07-2011, 05:22 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Question
Seems strange! I can only assume it is something to do with the direction of the machining marks, left when the braking surface was manufactured.
Old 01-07-2011, 06:11 AM
rickoshay45's Avatar
rickoshay45
rickoshay45 is offline
There was a factory recall. Seems a bunch of rotors got marked backwards. If I remember right, the round bulge on the rotor slots is supposed to be the leading edge. Check the FSM (I'm at work and can't) but mine has an explanation of how to mount them and identify the correct position and rotation.
Quick Reply: Backwards front rotor?
