License plate bolt light......
I'm moving my license plate to below the turn signal bar with a SoftBrake mount. I will have to find a way to light the plate. Has anyone here used the LED license plate bolts to do that? I was told by one guy that he tried it and used one on each corner but it only lighted the corner not the whole plate and you still couldn't read the plate at night.
I looked at them and thought the same- if you go that way, cyclegear ( chain store) has them for about $20 a pair.
in the end I got a roadking signal bar with undermount license plate- just had to splice the LEDS into the run light. I also used the rear lens with no window and the RK signal bar was a little narrower than the original bar on my Classic- which I liked
this is an 09+ rear fender, so wider. cost used from a forum Pal was about $100.
ended up like this:
ended up like this:
I don't know for sure, but I did buy a package of four for Ten bucks at the Pilot truck stop this last weekend. It looks like they wouldn't shine any direct light on the plate however. I am going to try a couple, or all four to see for myself. As it is, my smoked rear lens has an LED bulb so it doesn't light up my plate either. I'll come back here and post how it did work out.
I'm also going back to buy a pack of blue ones and am going to mount one in between my left hard bag and the rear swing arm facing to the rear. Maybe it will get me pulled over, maybe not. Time will tell!
aka Bob
aka Bob
ended up like this:
ended up like this:
My dealer has a license plate frame that has 4 LEDs across the top aimed down on the plate. If it will fit ok I think I'm going to try that.
I thought about the RK turn signal bar but I don't think the pre '09 is the same as the '09 and later. The fender is wider on the new bikes so it won't fit my '08 fender and I don't think the older Kings have the plate on the bottom.
Laydown tail light lens with clear bottom.
http://www.jpcycles.com/product/3400541
Tried to use these on an Ultra. Bought them on eBay. There isn't a lot of room to work and couldn't turn the wrench to tighten the nut onto the threads. Turned the threaded part of the light into the nut and twisted off the wires from all the roatation. Ended up buying the license bracket with the LED lights and it worked fine.
