2011 Electraglide - HD LED Signal Lights front and rear
Old 01-15-2011, 06:43 PM
sobr0716's Avatar
sobr0716
sobr0716 is offline
Default 2011 Electraglide - HD LED Signal Lights front and rear
Hi All.
I just installed the HD bar and shield LED taillights, stop light and front turn signals. I got the rears tail and turns installed they worked great! Installed the front turns and when I tested it my rear turns no longer worked. tail light still works but nothing from the LED turns in the rear. Fronts work fine. I have checked all fuses under the left cover and none are blown. Is there another fuse for the rear turn signals I'm missing?
Could I have knocked something off under the fairing that connects the rears?
Any help is appreciated!
Mark
Old 04-16-2012, 05:39 AM
Bill R's Avatar
Bill R
Bill R is offline
Stage I
Default Rear LED's not working
I have same issue after installing the the front LED's the rears don't work.. Did you figure out your problem..
Old 04-16-2012, 09:30 AM
White Ice's Avatar
White Ice
White Ice is offline
I had this same issue. Go back into your tail light and re-check your connections step-by-step with the instructions. After using a magnifying glass I realized that I plugged the two violet wires into the #2 slots on the mini connectors instead of the #1 slot.
bikernutgoofy
14
04-09-2015 09:05 AM
White Ice
04-09-2014 08:51 AM
Navy UC Rider
08-18-2013 05:32 PM
JC650
11-12-2010 03:59 PM
jcanrun
08-04-2009 01:47 PM
Quick Reply: 2011 Electraglide - HD LED Signal Lights front and rear
