Brake caliper rebuild + photos
Old 01-18-2011, 07:02 AM
straightleg's Avatar
straightleg
straightleg is offline
The caliper grease I used does not stay like grease. It dries and puts a slick coat on the metal parts so they slide back and forth
JUst a FYI
Straightleg
Old 01-18-2011, 08:08 AM
relli's Avatar
relli
relli is offline
i would never put anything other than brake fluid or brake assembly fluid INSIDE a hydraulic brake system
Old 02-05-2011, 12:48 PM
straightleg
I believe the thicker stuff holds back the brake fluid.
Stock brakes come with that ge versilube stuff that is thicker than brake fluid.
They say in my manual that coating your pistons with dot 5 will give you a spongy lever. It is a warning in bold letters
Straightleg
Old 02-05-2011, 02:27 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is online now
[QUOTE=straightleg;7791034] Reused all parts except new bleeder screw and new banjo washers.
Originally Posted by dawg
HERE is the instruction sheet for the $13.25 seal kit to rebuild all the calipers.
Sounds like there is a message there!
Old 02-05-2011, 02:39 PM
straightleg
Having only 14,000 miles on bike, I did not rebuild the front. Parts looked ok. Just cleaned it all.
Winter is not over, might go back in and put new seals and wipers in.
Just did the back brake. New seal kit and new pads. For $30.00 I should have put new seals in front.
I still went with the permatex coating on the pistons on back.
Straightleg
Old 02-05-2011, 03:46 PM
95hdtlk's Avatar
95hdtlk
95hdtlk is offline
I think you did a good job Straightleg. But I agree with some of the others about using caliper grease on the inside of the pistons. I too have rebuilt a lot of calipers over the years and always used brake fluid for lube. Never had a problem. I'd be interested to see over a period of time, if the caliper lube inside the piston bores causes any problem. Keep us posted.
Old 03-18-2011, 09:53 AM
Tripp_HPjunkie's Avatar
Tripp_HPjunkie
Tripp_HPjunkie is offline
great thread thank you very much
Old 03-23-2011, 07:02 AM
skdvr's Avatar
skdvr
skdvr is offline
Great write up Straightleg. I am going to be doing this over the next day or two since my front brakes are dragging.
Any tips you can pass along?
Phil
Old 03-23-2011, 07:28 AM
88racing's Avatar
88racing
88racing is offline
Nice write up and pics!
Old 10-27-2011, 12:32 PM
straightleg
Thought I would bump this. Winter project for someone
Straightleg
Quick Reply: Brake caliper rebuild + photos
