Glad to hear you're happy. I'm doing this in the next couple of weeks, whenever I get a refund on my extended waranty. I'm looking to replace lots of fork seals!
Im currently running a gear drive cam set up. Is the TW555 cam available in gear drive?? Id seriously look at this kit if it were. I guess I could put the chain system back in since I saved it. Any suggestions? Its either the Fuel Moto 107 or the S&S 106 with 583 gear easy start cams.....hmmmm, what to do?
Do you have a problem starting with no compression releases with this kit? That would be my main concern. Has Jamie indicated what the likely difference is adding head work to his kit?
It's an inexpensive add-on, if you don't need them, you are not out much coin. Then there is the pain in the **** of dealing with manual releashes. My bike came with automatic compression releases. Compression is 10.25:1 and Jamie states that they are not needed but I suspect in Houston's summers, they will.
