Disassemble Q for Road Glide custom painting
Hi. I am about to breakdown my 07 Road Glide for custom painting and I have a question hopefully someone can help answer.
Do I really have to remove both the front and back wheels to get the fenders off? Seems like I should be abe to at least remove the front one without taking the wheel off. And, can’t the rear fender be removed with the wheel intaked if the bike is on a jack?
Also, are there any suggestions or “got ya’s” to be aware of? It looks like a bit of a challenge to remove everything off that needs painting. Especially the inner and outer fairing. I am changing colors totally so everything that is painted will need to come off.
Any advice will be appreciated. Thanks.
Scott
Scott
The HD Service Manual for 2007 Touring Models, p/n 99483-07, will be your best friend for disassembly and reassembly. The tip on the shock bolts is a good one, but use it in moderation; i.e. lift the bike only enough to get to the rear fender bolt to avoid damaging the brake line.
Take pictures; use freezer bags or other containers for the various nuts, washers, etc. and label them so reassembly is easy. Label the connectors and/or use a Sharpie to mark connectors that are separated so you can reconnect them easily.
I disassembled my '04 EG in early '09 for a complete repaint and using the Service Manual, keeping parts in labeled freezer bags/containers made for a very easy project--tedious because of all the separate items involved, but easy since there was no confusion about how to put it back together again without problems.
Good luck with your project.
Carl
Carl
If you are carefull you can straighten the tabs that lock the fender bolts without removing the wheel and take off the fender. It is a little harder to unbolt the fender but is easier than takeing off the wheel. Just reach tru the wheel with a long screw driver to straighten the tabs.
Thanks for the tip OB. I will try and get to the tabs before i go thru the trouble of taking the wheel off. I just when for a short ride to get some gas stabilizer thru the bike before I take it apart. I will start on this tomorrow.
Scott
Carl
Carl
I will watch out for the brake line. Great tip.
Scott
I also did very little of what Carl suggested but I am not very smart sometimes (lazy more like it) either. I have 3 cups one for the front center and rear.
My thread ~ https://www.hdforums.com/forum/touri...nter-pics.html
I too have my bike apart for paint work...I did not take the front/rear wheel off.
Nice pics of your breakdown.
