Arnott vs Progressive air suspension
I have the Arnott laying on my work bench now, just waiting for my parts to come back from the painter. I went with the Arnott based on the price difference... I have heard some guys say the Progressives are worth the extra money but I just cant see how for me as I rarely have a chance to ride more than a couple hundred miles a day anyway. Good thread... looking forward to seeing some feedback on this.
Going with that set up there really isn't much difference in cost from what I have seen.
good luck with your decision
Don't do it before experimenting with different oil viscosities in your OEM shocks. You will find many posts here about changing the oil in your stock shocks. It is easy to do and might be all you need.
These aftermarket air shock people might be good, honest, and reliable, but in spite of what many on HDF say about shocks, they were engineered for your cycle. But of course they were made as "one size fits all".
So, by changing the stock shock oil viscosity from 5 wt. (OEM weight fill from Showa)upward, you might be able to fine tune your existing shocks to what suits you. Give this a try before spending $1,000 on yet another air shock system.
I have a new set of Arnott shocks on my FLHX, and have had Arnotts on my Vrod for 3 years. Their new model is based on the QA1 instead of the Aldan or Bilstein. The ride is great. Their customer service is top notch. I have the owner's cell phone, and call him direct at times. He has never turned down my calls.
Air Shocks
I here what your saying but here is my problem. I'am only 5' 5" tall, or I guess I should say (short). Anyway I have a 2010 SG that I installed a 2008 seat that I had cut down at the upholstry shop and I installed 1" lowering blocks on the stock shocks to get myself comfortable. (Feet flat when sitting still). That has ruined the ride in my opinion. Poor ride quality and bottoming out with rider on. I just thought this would be the way to go to get a much better and comfortable ride.
Look I am a short guy also much to my dismay. I have tried a number of combinations looking for the magic ride and lowering at the same time. I spent the 1000.00 for the Arnott.Bilstein shocks and was very unhappy with them. I tried every conceivable setting with air pressure and rebound setting. The ride was horrible. They were great in the garage at the bottom end or in a parking lot but I ultimately sent them back. Some guys really like them. I have tried lowering blocks and progressive 11" shocks. I have settled in on Bitchen Bagger 10 3/4 air shocks. Is the ride great. No, but it's far and away better than I got with the Arnotts and at least as good as stock. No matter what you do if you shorten the travel you'll always give up quality. The ride I have now is very adequate for me. I have no complaints and it's also low enough . I never bottom either. I run 25 lbs of air and its all good. I also use a C&C seat with the sides shaved to get me lower. I can ride all day with little or no issues. Hope this helps..
Hotrock
He compaired it to a Corvette vs a Buick suspension and ride???????
I was hoping to here from someone that has this system with the Aldan shocks to get their opinion.
