Best price on a 120 r
Others running Jim's 131, Big Bore 117's/124's are running stock belts without a issue. Time will tell but I think it will be good with the stocker.
She rocks, when the rest of the country was quoting 60 day lead time, we got ours in 10 days. your going to love it.
And for the poster that asked about the 103/107. I was in the same boat, why spend the same amount of money on a 107 (built very well with crank work,head work etc) when for a few bucks more you can have a factory 120 crate.
SPORacer, make sure you get a good 2-1 exh to let that sucker breath and a good clutch. I went with a Rivera Primo Pro with the gold spring (silver spring will not hold the power) and a VPC from AIM. Lots of guy worked up to this combo after trial and error on other products. If you have a death grip of a handshake with your left hand, the SE clutch will also work but is not really street friendly due to pull needed to engage. Good luck with your motor, welcome to the 120R club!
If anyone wants more info on these motors (a inside look and the story of our build) check out this thread for a lot of good info.
http://www.*****************/forums/tw...ins-120rs.html
with all the $$$$ I put into my 117" build I would have definitely been better off going with the 120. If I were to do it again that is the way I would have gone. My 117" was somewhere in the $7k range for the motor work(not including the clutch because I would have had to deal with that regardless).
I just checked and the clutch has a black spring so i guess that will have to be upgraded too.
i have a d&d fatcat with a wraped performance baffle but i was thinking of selling it and going with a borzilla. Its 1 3/4 versis 1 7/8 primary pipe size.
