fork seal installation...?
Old 02-25-2011, 09:43 PM
CC Rainman's Avatar
CC Rainman
CC Rainman is offline
Check this link out. It's from the BigDog site but almost the same concept. It has the picture that your looking for.
http://www.bigdogbiker.com/forums/ho...our-forks.html
Old 02-26-2011, 08:34 AM
rg_dave's Avatar
rg_dave
rg_dave is offline
Great link. That is exactly what we did but with much better pics than I can take. We used a shorter piece of 2" pipe, about 18".
Old 02-26-2011, 09:32 AM
DamifIknow's Avatar
DamifIknow
DamifIknow is offline
I took a 2 foot piece of 1 1/2 pipe and cut it down the middle. Streched it over the fork tube and that worked fine for me. I tapped the seal in with a rubber mallet. When I was done I threw the pipe away. Why would I keep a cut piece of PVC?
Old 02-26-2011, 10:17 AM
nahanhoku's Avatar
nahanhoku
nahanhoku is offline
Originally Posted by ElectraHead
Does anyone have a pic of this home made pvc seal installation tool. I am pullin mine apart tonight and would like to save the money and make my own tool.
thanks in advance
Here is what I used
Old 02-26-2011, 11:22 AM
DTTJGlide's Avatar
DTTJGlide
DTTJGlide is offline
Why doesn't that thumbnail enlarge?
Old 02-28-2011, 06:33 AM
Ridin'withTheKing's Avatar
Ridin'withTheKing
Ridin'withTheKing is offline
I think I'll look into the PVC solution. It sounds like a viable, cheap way to do this. Thanks for all your responses!
Old 02-28-2011, 06:46 AM
smokindave's Avatar
smokindave
smokindave is offline
Here is what I use to do mine. I use a 1 1/2" PVC pipe split down the middle to seat the the seals. I also take the tubes off the bike and work with them in a vise. Best to use an impact to remove the 6mm allen bolt on the bottom of the fork leg, it can be tough to get loose. Good luck
Attached Thumbnails fork seal installation...?-img_2210.jpg   fork seal installation...?-img_2212.jpg   fork seal installation...?-img_2211.jpg
Ridin'withTheKing
02-24-2011 10:30 AM
Figstr
10-09-2009 02:28 PM
SkyRider
04-24-2008 07:56 PM
20FXST06
09-10-2006 12:20 PM
20FXST06
09-10-2006 01:34 AM
Quick Reply: fork seal installation...?
