2010 FLHX Exhaust Bolt Problem
Also posted in another forum:
Just a heads up to those of you riding 2010 Street Glides and Road Glides with the factory 2-1 exhaust, seems the bolts that hold the exhaust bracket to the transmission have a habit of coming loose and falling out. A couple of shops that I talk with have mentioned seeing this problem quite frequently.
First indication I had was a transmission leak on the right side of the bike. Had the bike up on the jack to install my new amp and a small puddle of fluid "appeared" under the right side of the transmission over night. Got to looking around and found the two bolts that hold the bracket to the transmission gone. Talked to a couple of techs I know and they replied that the problem has been occurring fairly often.
Now to the fun part, in my case looks like I will have to pull the exhaust to install the bolts. I talked with the service manager at the dealer about this being a warranty issue and he wouldn't take it in to replace the bolts but did give me the bolts. Said something about it being my problem since I had after market exhaust. I argued that it shouldn't be an issues since the D&D exhaust was designed to use the stock bracket. He still declined to do the work.
One annoying thing here is the fact that I have bought two bikes and an engine through this dealer in the last 16 months. Seems like there could have been a little consideration shown on the exhaust warranty issue. Guess they must be too busy in the shop..
I have already used the cut off wrench trick to reach a couple of the other bolts. Problem in my case, not enough room to get the bolts that are missing back through the bracket and started into the transmission because the exhaust is in the way. Seems on a stock headpipe you can use a ball driver to slip the bolts in but on the D&D there isn't enough room.
I recently bought a new exhaust bracket and had it powder coated black.I have been wondering if there was enough room to get the bolts out without loosening the pipes.I've read on here many times of missing bolts,but it never sunk in to my thick skull,that there was enough room for the darn things to fall out.Thanks.
Moonrunner
15
10-18-2010 11:38 AM
