My Quick n' Dirty Fairing Bracket Repair
Old 02-27-2011, 06:48 PM
soos's Avatar
soos
soos is offline
Thumbs up My Quick 'n Dirty Fairing Bracket Repair
Last weekend I pulled my outer fairing off to replace a burnt out bulb in my fuel gauge. While I had it off I decided to do a little nosing around and discovered a broken bracket. Then I checked the other bracket and found it broken too. Sure why not? Double the pleasure, double the fun. Anyway I went into work the next morning and fabbed a pair of quick 'n dirty brackets. I hard soldered 2 reinforcing pieces top and bottom across the 90* bend of the mounting tab for extra rigidity. Then I drilled a 3/8" hole in each tab and inserted a 1/4" ID x 3/8" OD rubber grommet to act as a dampener when the bracket is bolted to the inner fairing. Painted it black and riveted it to the OEM bracket.
For those who can't or don't want to go thru the trouble of doing a homemade fix there is an after market KIT available.
Attached Thumbnails My Quick n' Dirty Fairing Bracket Repair-cid__0227111642.jpg   My Quick n' Dirty Fairing Bracket Repair-cid__0227111647.jpg   My Quick n' Dirty Fairing Bracket Repair-cid__0227111714.jpg   My Quick n' Dirty Fairing Bracket Repair-cid__0227111715.jpg   My Quick n' Dirty Fairing Bracket Repair-cid__0227111738a.jpg
Old 02-27-2011, 06:57 PM
JRBass's Avatar
JRBass
JRBass is offline
Nice Quick fix. I think I will be bookmarking this one as this seems to be a problem with our baggers. Thanks for the info and Pics.
Old 02-27-2011, 06:58 PM
dawg's Avatar
dawg
dawg is offline
Received 2,950 Likes on 1,709 Posts
Looks great, saves some cash. We coulda changed out your brackets on Friday night and stayed up till 4am again, you're no fun! Had to go fixin' things on your own
Old 02-27-2011, 07:00 PM
alkrisma's Avatar
alkrisma
alkrisma is offline
good job. what yr is the bike?
Old 02-27-2011, 07:07 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
Very crafty - great fix...saw a similar one on another forum that used all screws vs. rivets, but still looks good.
Old 02-27-2011, 07:15 PM
soos's Avatar
soos
soos is offline
I dunno, somethin' just isn't right about lettin' a guy work on your scoot and the only tool he knows how to use is a 5# rubber mallet.
Attached Thumbnails My Quick n' Dirty Fairing Bracket Repair-cid__0225111338.jpg   My Quick n' Dirty Fairing Bracket Repair-cid__0225111032.jpg
Old 02-27-2011, 07:16 PM
soos's Avatar
soos
soos is offline
Originally Posted by alkrisma
good job. What yr is the bike?
'06 EGC.
I opted for the rivets because they do stand up to vibration very well. If in the off chance they do let go, they are easily drilled out and I will already have holes that I can expand for bolts and eliminate the need for drilling additional holes in the OEM brackets.
Old 02-27-2011, 07:18 PM
dawg's Avatar
dawg
dawg is offline
Don't know what you're talking about...........must be a cardboard cutout you set up with a rubber mallet to photograph
Old 02-27-2011, 07:58 PM
krazy3's Avatar
krazy3
krazy3 is offline
Nice job SOOS. I did the same thing a couple of years back, except for the reinforcement.
Old 02-27-2011, 08:54 PM
Guntoter's Avatar
Guntoter
Guntoter is offline
One problem I have had with the Bagger Parts bracket is that it does not fit if your stock bracket is not broke. The hole for the standard bracket bolt is in the wrong place and will not line up with the stock bracket. I have no idea why they made it this way, makes no sense at all and would have been just as easy to have put the hole in the right place in the first place.
Quick Reply: My Quick n' Dirty Fairing Bracket Repair
