What would Cause Handle Bar shake?
Old 03-20-2011, 10:17 AM
smat45's Avatar
smat45
smat45 is offline
Have you taken the outer fairing off to see if the fairing mounting brackets are ok?
smat
Old 03-20-2011, 10:19 AM
JoshuaCannon's Avatar
JoshuaCannon
JoshuaCannon is offline
The rumble of my motor
Old 03-20-2011, 10:50 AM
Cheech2010FLHTK's Avatar
Cheech2010FLHTK
Cheech2010FLHTK is offline
Wouldn't the dealer have fix any recalls prior to sale if the recall was made prior to the purchase date of the bike? The fuel tank recall was in nov '09 purchased the bike in June 2010. Or is that to much to expect from the dealer? I would not be surprised
Originally Posted by SixSixRider
This has come up before and generally seems to be related to preload on the neck bearing:
https://www.hdforums.com/forum/touri...nd-wobble.html
As noted in this other thread, there's an HD service bulletin on the subject. My '09 Road Glide has the same issue and I have yet to deal with, so I keep my hands on the grips.
I did search for recalls and service bulletins and the only one that comes up is for the fuel tank brackets.
smat
Haven't pulled the fairing.
Old 03-20-2011, 10:53 AM
Cheech2010FLHTK
Much more shake then the normal Harley motor rumble Joshua thanks
Old 03-20-2011, 12:33 PM
ctso030's Avatar
ctso030
ctso030 is offline
i would jack up the front tire spin it around , see if the brakes are dragging. then look at the tire whle spinning it to see if it is out of shape
Old 03-20-2011, 06:33 PM
smat45's Avatar
smat45
smat45 is offline
Haven't pulled the fairing.[/QUOTE]
If you've never done this before, put something soft on the front fender...trust me. Check it out in there. I had both of mine crack and replaced under warranty.
smat
Old 03-20-2011, 06:58 PM
Aslan's Avatar
Aslan
Aslan is offline
My last bike did it and I never could figure it out. It was fine at higher speeds it only did at at slow speeds. I couldn't feel any shake or vibration when I had my hands on the bars at any speed.
My new bike doesn't do it. Smooth and straight with hands off at all speeds.
Old 03-20-2011, 07:03 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is online now
Mine shake pretty good at idle,especially the throttle side.
On the road with no hands,no shake at all.
Old 03-20-2011, 07:08 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
Originally Posted by CSMHOG
I wouldnt think throwing a weight would affect the shake at idle.
Likely ain't related. Rough idle would shake the bars.
Old 03-20-2011, 07:52 PM
thecort's Avatar
thecort
thecort is offline
If you're saying it shakes at idle you should check your motor mounts.
Quick Reply: What would Cause Handle Bar shake?
