06-07 Harman Kardon Radio Troubles
After riding in the rain for several hours yesterday, the display on my HK Radio is blank. It still is red, but I can't see anything on the screen. Has anyone else experienced this? It almost seems like the contrast needs to be adjusted, but I can't see the screen to know where I need to adjust it. Is there a way to set it back to factory default so I can see what is on the screen? Other than the display, every this seems to be in good working order (CB, WB, FM, Intercom, AUX etc.)
RE: 06-07 Harman Kardon Radio Troubles
Just got my new Harmon Kardon installed on my '06 SG this morning...the display was freezing up and the controls would not work.
While they were repalcing the radio they noticed that I had two more broken brackets (both upper fairing brackets broke a couple of months ago), these bracket run horizontly and terminate at the lower outboard speaker screw.
They said that they've seen this a few times before on the StreetGlide model? They replaced them under warranty.
I rode for 2 days in the rain this summer no problems with water but i have always had a problem with my radio giong into full static volume the only way to fix is turn radio off for 30 seconds the back on works for a while then it will happen agian at no set interval 3 HD Dealers and no one can figure it out is there a site to ask Harley for help
lost my display once and found out that I dimmmed the screen somehow and bought it back.Nut I have also had moisture behind the display and had dlr repalce it,Washed the bike and I covered the radio and still got a little moisture in the display and thats been two months ago.Just gonna live with it now....
