Installing SE compensator kit w/pics
Old 03-27-2011, 09:50 AM
HDV-GLIDE's Avatar
HDV-GLIDE
HDV-GLIDE is offline
Originally Posted by dansflhti
Thanks for the great write up and pics.Does grinding away the material on the inner primary create any problems?Like weakening it or creating a possibility of an oil leak?
No & No....You only take off a small amount of the aluminum in two areas. No chance of an oil leak. Did mine last year and no issues except a primary that make hardly any noise now and smoother shifting (or so it feels).
Old 03-27-2011, 09:53 AM
bowa18's Avatar
bowa18
bowa18 is offline
I failed to mention.... all the stock comp parts looked in excellent shape (25,400 miles on them). No wear, nothing damaged or broken. It probably would have lasted the life of the bike??? I just hated all the slop I could feel at low RPM's.
Old 03-27-2011, 09:57 AM
hubble's Avatar
hubble
hubble is offline
nicely done, thanks
Old 03-27-2011, 10:00 AM
Ronp42's Avatar
Ronp42
Ronp42 is offline
Account Retired
Originally Posted by PDDGM
Great write up and pics. What was the purpose of grinding the case?
Joe
Read the start of this Thread and he explains why
sfchief's Avatar
sfchief
sfchief is offline
Excellent toutorial, thanks for taking the time.
Old 03-27-2011, 10:02 AM
gmc's Avatar
gmc
gmc is offline
Nice job, it took me forever to grind enough material. I was just using a grinding wheel I had for sharpening mower blade. Do you have a pic of what you used even though it's too late for me maybe help in future. Of coarse afterwards I found some more aggressive grinding wheels.
Old 03-27-2011, 10:09 AM
cromagnon's Avatar
cromagnon
cromagnon is offline
I don't think my 05 needs this fix but will save it in case I ever buy an affected model year. This should be an extended warranty issue, but of course I know how that goes.
Old 03-27-2011, 10:12 AM
bowa18's Avatar
bowa18
bowa18 is offline
No, sorry I don't have a pic. It's a metal cone shaped de-burring tool (kind of like a small metal pine cone). It made quick work of the grinding process. anything made to grind metal will work, the case is aluminum so it cuts like butter.
Teardrop's Avatar
Teardrop
Teardrop is offline
Nice writeup. Mine has started making the clunking sound but I am going to see if the dealer will fix under warranty before I tackle myself.
Old 03-27-2011, 10:14 AM
traveler's Avatar
traveler
traveler is offline
Does my 2011 come with this from the factory?
~Joe
Quick Reply: Installing SE compensator kit w/pics
