Smaller Compensator Sprocket vs Cams
My goal is to get a bit more bottom end (ok to lose "some" topend). I had been thinking about 255 cams, but lately have been thinking about going down a couple of teeth on the front compensator sprocket. I have heard though, that you can't get a smaller front primary sprocket and still retain a compensator on a 2009 model?? Any ideas here? My bike has rinehart slip ons, screamin eagle air cleaner and hd remap. Just thinking that a simple sprocket change should give a similar "seat of the pants" improvement as cams do, with a lot less work and $$.
Thanks for your help
coming from dirt i used to play with gearing all the time i think u would be surprised how much improvment u could get in low end without loosing much if anything on top.if u want to retain compensator there is a larger ring gear for the cluthbasket.its only a couple of teeth.not to sure about your stock gearing it is already a tad lower than my 07,but my motor will not pull 6th gear to redline so i might even gain top end with lower gearing?
I was thinking of changing engine or trans sprocket to. I was just wondering if it would mess up 6 gear indicator light.I don't know if computer reads engine speed to trans speed to trip light. I believe it does,I haven't had time to call thundermax to see if it does and if so,if they allready have the number to put into computer.If someone allready knows could you post. Didn't mean to jump on your post.Thankyou
I changed out the Comp sprocket with a solid 30T sprocket in my '09 King..... nice change ..... and losing the comp sprocket is not a bad thing.......... it cleaned up a bunch of the clunky "slop" that my primary had.... all good in my experience....
oh ya... sixth gear indicator light does NOT work in my bike after this change and my speedo reads about 3MPH over at 70MPH... it may have before, I never checked it.....
this might sound dumb, but i'm curious. by changing out the compensator for a sprocket with fewer teeth, or by changing out the clutch basket with more teeth, either would lower the gearing of the final drive ratio. this would still allow the speedo to operate like stock because the front pulley sprocket and rear drive wheel sprocket remained the same and the speedo is fed information from the transmission, right? if this is correct then it'd bring an 08 tall geared bike to where the 09 and later models are geared which would be an improvement. let me know if i got this right. i hope this made sense.
The easiest way to match 09 and up bikes is by going to a 68T Sportster sprocket.
There's a thread on it here. I did it on my 07 and am happy.
