Wind Deflector Kit Install - 2011 RGC
Old 04-03-2011, 12:03 AM
wachuko's Avatar
wachuko
wachuko is offline
Post Wind Deflector Kit Install - 2011 RGC
Just finished installing the air deflectors for the front (Wind Deflector Kit - 57000063)
Took, what?, two minutes? hehehehe
Very easy to install...just make sure the front wheel is not locked to the side so you can insert the left deflector (if looking from a seated position on the bike). The deflector just clips to the crash bar and the gas tank mount.
Old 04-03-2011, 06:44 AM
horsefoots's Avatar
horsefoots
horsefoots is offline
Is it effective?
Old 04-03-2011, 06:49 AM
shortride's Avatar
shortride
shortride is offline
It doesn't look like the wind deflectors would work on an Ultra Classic with lowers.
Old 04-03-2011, 07:08 AM
98Ultra's Avatar
98Ultra
98Ultra is offline
Doesn't look like a Harley part number. What brand are they?
Old 04-03-2011, 07:14 AM
Roadan's Avatar
Roadan
Roadan is offline
Don't think they would work with fork mounted fairing
Old 04-03-2011, 08:18 AM
reh13's Avatar
reh13
reh13 is offline
Haven't seen those before, where did you get em'.....and do they work.
Old 04-03-2011, 10:16 AM
skratch's Avatar
skratch
skratch is online now
Received 4,183 Likes on 2,453 Posts
yes, they are harley branded. yes, they do work. but, they are for the road glides, not batwings.
there is a caveat though, if your bike has had the fuel tank recall done, then they will not fit directly out of the box. in my case, i just got a slightly longer bolt, and a nylon spacer to give the extra area for the deflector to hook on to.
Old 04-03-2011, 10:34 AM
wachuko's Avatar
wachuko
wachuko is offline
Yes, these are Harley Davidson parts: http://www.harley-davidson.com/gma/g...1&default=none
Standard items on the '11 CVO Road Glide.
As Skratch mentioned, these will not fit without modification if you have a '10 with the fuel tank recall.
Feedback from other Road Glide riders is that it works. I still have not put the bike back together to test.
Old 04-03-2011, 10:38 AM
marvincbr's Avatar
marvincbr
marvincbr is offline
I'm interested to see how they work out. I just saw them on the CVO RGU yesterday at the dealer...
Old 04-03-2011, 11:08 AM
Tek74's Avatar
Tek74
Tek74 is offline
Upon arriving home with my new RGC two months ago, I snapped on a set, along with a 12" WindVest shield. The wind does not beat me up at all. Oh yeah, I also added that $30 half moon shaped chrome thing under the fairing, but I can't remember the HD part number. For those considering an inexpensive comfort improvement, I say give this 2-pc part a try. Worst case scenario is you are out $30. The only other anti-buffeting solution I've heard of is lowers.
Quick Reply: Wind Deflector Kit Install - 2011 RGC
