What did you do to your bagger today?
Old 10-19-2014, 12:02 PM
Dr. Tiki's Avatar
Dr. Tiki
Dr. Tiki is offline
Was at an Octoberfest event and picked up this chrome beer bottle opener and when I got home decided that I needed a little project.
So took this:
Removed the label, drilled a hole, bent and mounted:
and tested:
  #6592
Old 10-19-2014, 12:53 PM
highwayman1224's Avatar
highwayman1224
highwayman1224 is offline
So took this:
and tested:
That's different, I like it!
  #6593
Old 10-19-2014, 01:19 PM
Punjabi Rider's Avatar
Punjabi Rider
Punjabi Rider is offline
Just finished installing WO 575 bars on my 07 Ultra took few hours to install the wiring harnesses internally too many pins to remove from the connectors and insert them back in right order. Very clean look and lot more comfortable then my stock bars used all the stock cables, wrings and brake line just had to re route everything.
  #6594
Old 10-19-2014, 05:41 PM
Bong's Avatar
Bong
Bong is offline
S&S intake; Rinehart exhaust; Stage 1 upload; Progressive performance shocks and fork springs; skull horn cover; 12" LA Choppers handlebars; HD grips; Blackout front end; Shaved seat; Black Diamond floor boards, pegs, toe and heel shifter; and custom derby cover! Almost done...maybe
  #6595
Old 10-19-2014, 08:18 PM
AJGrey's Avatar
AJGrey
AJGrey is offline
Well this weekend Me and my kids replaced my stock exhaust with some V&H 2into1's and I took my youngest on his first ride. Good times.
  #6596
Old 10-20-2014, 07:05 PM
PSYCLE's Avatar
PSYCLE
PSYCLE is offline
Limited- Cleaned the air filter, spots on with high beam mod and installed the garage door opener in the dash.
RK- nothing..... today.
  #6597
Old 10-20-2014, 08:20 PM
Scaffido's Avatar
Scaffido
Scaffido is offline
When you say shaved seat, did you send it out or do it yourself? It looks lower and more back support. Kind of what I want to do to mine.
  #6598
Old 10-21-2014, 02:50 PM
GibsonSG05's Avatar
GibsonSG05
GibsonSG05 is offline
I added these $30 LED turn signal / running lights with clear lenses off ebay. They look pretty decent so far for $30.
  #6599
Old 10-21-2014, 09:13 PM
Roadblok's Avatar
Roadblok
Roadblok is offline
Stage II
Just rode. Got home and plugged in the trickle charger.
  #6600
Old 10-21-2014, 09:56 PM
houstonhdguy's Avatar
houstonhdguy
houstonhdguy is offline
Added vented lowers...
Quick Reply: What did you do to your bagger today?
