What did you do to your bagger today?
#7502
The Rineharts were getting a little tacky so--a can of high temp black paint and 1/2 dozen new stainless clamps later---the exhaust doesn't look like the 50K it has on it.
#7504
Replaced the rear tire and finally with the help of the forum, was able to tighten the rear axle without the cams moving.Got the belt adjusted and ready to go.
#7505
installed the big sucker air cleaner this afternoon, fairly simple and straight forward. Debating if I'll use the football cover, you do hear the air being sucked in when laying on the throttle. <br/><br/>Setup: decatted headers, CFR slip ons, big sucker air cleaner<br/><br/>As for the PC-V map, currently using the following:<br/>#046: CFR slip ons without insert, screamin eagle air filter<br/><br/>Sounds solid and not much decel popping from what I've noticed so far. Suggestions thoughts on which map to usE
#7506
I installed my hidden seat bag storage unit.
Yep- my idea, for a long time,
ya see ya have this slot cut into the stock seats on road kings and classics and limiteds etc.. its made so that the rider can install a back rest and hook it into the frame. a person can put his hand down that slot and there is a lot of room in there.
so I went to Goodwill and found a black womans leather purse that wasn't very complicated and made a few cuts on it so I could attach it to the bottom of the seat then took some epoxy and some tacks and attached it to the seat, so that you can use that as a storage space for what ever might fit. bandana, glasses, sunscreen, snacks, works great.
cost? $3.99 for leather purse
had the tacks and epoxy.
#7507
Answered the phone Iron cross called my radio is on the way back repaired. Left it all a part while I sent it in just did not feel like putting it back together while waiting on the radio.
#7509
I tried to make a video of the aftermath with my phone. I have go pro 1. So far no dice. sound quality isn't that good. I found a couple videos online and the best one that I could fine is one of a street glide. The pipes have a deeper sound to them.
I went for a ride. Highway speeds up +, Very tolerable. Best $20 I have spent in a while.
