What did you do to your bagger today?
#7881
103 ci 120 hp. 113tq
MVA HEADS
10:5:1 Forged SE Pistons
259E Cams
Bassani road rage 2:1
Welded Crank
RC Cyles Dyno tune TTS Mastertune
MVA HEADS
259E Cams
Welded Crank
#7882
Added ClutchWiz to reduce clutch pull (about 40% easier), was a simple thing to do. Removed fairing to add Polk tweeters, found a broken bracket tab, fixed using the extensive info in this forum(),generally straightened up wiring, installed SuperShox.
#7883
Over the last couple of weeks:
- Finished 'stage 1' by installing S&S Power Tune pipes and tuning flashing appropriately by way of FP3
- Installed Electra Glo saddlebag lights
- Installed saddlebag guards
- Audio upgrades: "magic box", line driver, RF PBR300X2, Polk MM651
It's nearly how I want it ... I think that the bars are next ...
#7884
Preventive maintenance
I dropped my 12 SG off to have installed S&S 551 EZ Cam Kit and convert to gear driven cams from hydraulic tension which will eventually cause catastrophic damage. My 12 SG has 48k+ miles. After the bill, no more worries. Ask me how I know or check out;
http://www.baggersmag.com/twin-cam-e...ank?imagine=17
#7888
Installed custom dynamics lights in front and rear , led headlight , and stage 2 boom audio. I had the local dealer perform the radio flash after I installed the amp and speakers.Did all this last week and couldn't be happier with the results.
