PCv and cruise control on an ultra...hello?
I added a pcv from fuel moto....runs great...blah blah blah but my cruise control isn't working!!!!!!!
2010 ultra. I get the orange light when the console's switch is on but it will NOT set.
anyone have this trouble? Do I have to set something under "harley ecm" settings on the power commander 5?
I'd rather ask before going into pulling the pc off, checking fuses and the rest.
PLEASE HELP!
-Tony
PLEASE HELP!
-Tony
PLEASE HELP!
-Tony
PLEASE HELP!
-Tony
Cale
Okay, now you have me wondering if the cruise switch that I replaced last year on my '07 Ultra was really the problem. I will have to check the HD ECM setting on my PC-V. I was having the same problem as you describe. Seems to have gone away, but the bike has been on the lift since November and I am not back home yet from being a winter Texan. No hurry to get there anyhow since the weather in WI is crappy right now.
My advice is to try everything you can before replacing that danged switch unless you are going to have the dealer do it. The whole bike seems to have been designed around it. Holy cow! What a PITA it was to change it.
Cale
i know that i got the cruise control put on my bike when it was new, an 08 streetglide and it worked great. then i took the bike back in to harley a week or two later to get the stage 1 download and it killed my cruise. i made a u turn and went right back to harley and they fixed it. now a few months later i installed a pcv when they first came out and didn't have any issues with it being compatible with my ecm at all. it came pre packaged with the supposedly right canned map for my bike. the map was all wrong but the pcv did not affect my cruise.
Same problem with 2010 Limited on the Cruise not working. Was instructed to turn off the Harley ECM settings and all good. Also my 6th gear light would quit working at the same time. This would tell you if it was the switch causing the problem or the PCV as the switch has nothing to cause the 6th light to go out at the same time as cruise. This only happened when I had been riding about 5-6 miles at steady highway speeds. After stopping it would reset after a few minutes and work again for a while.
