J&M amp blowing fuses!
Old 05-01-2011, 10:31 PM
Hydroboy35th's Avatar
Hydroboy35th
Hydroboy35th is offline
Default J&M amp blowing fuses!
Every time I turn my ignition on it blows the fuse in the power cable and I can't figure out why????, I've tried a few different grounds and triple checked all my connections any ideas guys?
Old 05-02-2011, 01:47 AM
BBStacker's Avatar
BBStacker
BBStacker is offline
You didn't say how long you have had the system installed. Check for chafing, pinched wiring in the system for starters.
Good luck.
Old 05-02-2011, 06:27 AM
Silverearl's Avatar
Silverearl
Silverearl is offline
Okay here is one thing that you might want to look at.If it only blows when you start it the I would look at the power source and change it. It is more then likely tied to the main starter lead. You might want to tie it in at the fuse block or in the block for the radio.
Good luck.
Old 05-02-2011, 06:32 AM
Hydroboy35th
It's brand new I'm hooking it up for the first time, there isn't any pinched wires nor do they looked chafed. I have no idea what would cause it to blow a fuse everytime I turn it on. I'm gonna call j&m later today.
Old 05-02-2011, 06:33 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Wrong size fuse?
Old 05-02-2011, 06:37 AM
Hydroboy35th
Originally Posted by 1flhtk4me
Wrong size fuse?
I thought about that too, just wouldn't think j&m wouldve stuck the wrong one in there, it's a 20amp fuse by the way!
Old 05-02-2011, 06:54 AM
banks727's Avatar
banks727
banks727 is offline
You may have been right the first time. It could be your ground. My amp was very sensitive to ground. Do a search. There are a few good articles on grounding the system during install.
Old 05-02-2011, 06:56 AM
Hydroboy35th
Do you think I should take the paint off the frame where the ground is?
Old 05-02-2011, 07:24 AM
woosh's Avatar
woosh
woosh is offline
Deffinitly...
Old 05-02-2011, 07:40 AM
jjnoble's Avatar
jjnoble
jjnoble is offline
No.....The threads should be clear of paint and the bottom of the (head of screw), that is all you need. If you take paint off your frame, it will rust.
Quick Reply: J&M amp blowing fuses!
