Odometer/Fuel Range Indicator
"08 FLHTCU - Have had the bike since new and the range indicator has always worked when cycling thru the odometer, 2 trip meters and the fuel range. Now, I can not get the range indicator to show. Odometer and 2 trip meters work just fine. Fuel gauge (and all others) works just fine. No fuel range any more. No changes to the bike in any way for a while so can't figure why this would just stop working. Any ideas.
Tried an alternative to disconnecting the battery by just pulling the Maxi fuse. According to the owners manual this supposedly kills everything except power to the starter which should not be an issue. Bottom line, it did not work. Still have only the odometer and 2 trip meters. No fuel range indicator. Any other ideas? When I get another chance to do so I might try the complete battery disconnect just to see if it make a difference.
