I did a Google on the Harley wobble, which brought up the swing arm issue that the pre-2009 FL frame had with rear wheel steering in turns and its relationship to Harley's engine isolation system. I do not know if other frames have the same issue.
Rear steer is real. It is easily handled by an aftermarket stabilizer. There are many different manufacturers, but they all get the job done.
There was a time here when there were many threads on the subject at the same time. [YAWN]
Had experience the wobble twice in last 85K miles once was at 75+ mph on a slight curve on hwy80 side swipe the left side against the center divider but got under control, then found out it was combination of loose goose neck front tire out of balance and worn out front bearings.Since then I keep an eye on these things but I admit I'm guilty of riding aggressively.
