How do I go from Heel-Toe to just Toe shifter?
When you remove the heel shifter you have two options for the toe shifter positioin. When I removed my heel shfiter I installed a heel shift lever eliminator
http://www.kuryakyn.com/Products/71/...ver-Eliminator similar to this one that way I get a little more room for shifting.
Or you can get the type that mllgator describe to cover the end of the spline.
I wouldn't do it. I kept my front shifter adjusted to be able to use it as a regular shifter. I replaced the rear shifter with a long one from Walter's Workshop. I adjusted the rear arm so it is low, up shifts are about even with the floor board. I usually only use the front shift arm for up and down shifts especially if I'm wearing casual shoes, but if I have some big boots, I can still heel shift if I need. I got big feet and it works good for me. My not serve your purpose but something to think about.
If you look on the bottom of the shifter assembly, you will see a small (allen) set screw. Loosen the set screw and the heel portion of the shifter assembly will slide off.
Harley makes a cap to cover the exposed spline. It took longer to write this than to complete your project.
