Whats best for more light on front of Road Glide
Old 06-12-2011, 01:51 PM
mikeshog's Avatar
mikeshog
mikeshog is offline
for those still interested, I went with the Hyper Lights--small 2" LED's, total of about 12 on a side. Hide's well against the ford on the front fender and is quite noticable "blue/white) light. Nothing against Moto or Kuryakyn but i really didn't want to clutter up the front end any more than I had to. Will try the Hyper's out for a while and I can always change out to the hyper if I want more light. Thanks for all the reply's.
Old 06-12-2011, 03:52 PM
skootchnc's Avatar
skootchnc
skootchnc is offline
I run the HD fog lamps, mounted them on the engine guard.
Moto-Lights... while spendy, work well. If you're handy, you can get basic "P-clamps" and mount ant number of fog/driving lamps onto the guards
Old 06-12-2011, 04:25 PM
Road Hawg's Avatar
Road Hawg
Road Hawg is offline
I am running HIDs from DM tuning and I love them. FYI on my RG I was having trouble with both lights firing when I started the bike I went threw a few ballasts with motorcycle metal, then I hooked up the acc switch to my head lights so I can turn them on after the bike was running no issues since then, I think the two bulbs take just a little more amps then a single bulb so they don't always fire.
Old 06-12-2011, 09:29 PM
houstonhdguy's Avatar
houstonhdguy
houstonhdguy is offline
Post up a pic of your new light set up if you get a chance. Would like to see how it looks.
Thanks
Old 06-13-2011, 03:57 AM
bklynbob's Avatar
bklynbob
bklynbob is offline
You can rewire your lights w/ a relay kit more current= more light
www.easternbeaver.com
Old 06-14-2011, 07:08 PM
roadglidenut's Avatar
roadglidenut
roadglidenut is offline
1st Gear
Smile
You can also get fork mounted lights that turn when you turn the handlebars. I took the "engine guard" lights and mounted them off of my floorboard brackets for a ceaner look-however I found that I was scrapping them on hard turns. They also make an add-a -light to where the blinker mounts so you have the blinker and the add'tl light in the same mounting location.
GL
Have added LED bulbs to the stock headlights but need to keep them on high to be seen. I want to add light but not too excided about adding to the engine guard. What other options have people used to get better visability?
thanks,
mike
Bryant
11-16-2017 11:19 AM
Snowlj
10-11-2017 04:28 PM
kryingame
11-10-2015 03:03 PM
mikelikesbikes
08-07-2015 10:39 PM
hardyf111
11-04-2008 05:33 AM
Quick Reply: Whats best for more light on front of Road Glide
