How I conquered my 07 heat demon
Oh yeah, if you ever rode and 07 EFI twin cam (mine is an ultra classic, but the heat demon problem exists on all 07 twin cams), you know what I am talking about. Runs fine as long as its moving over 10 MPH, but a few stop lights, NYC stop and go traffic, etc, and your *** will be on fire. So I finally conquered my heat demon. NOW, it finally runs amazing. Great summer ahead of me.
a. oil cooler. noticed a big time difference, but the heat demon was still an unwanted pax.
b. Parade fan. definitely scares the heat demon off, but the demon will play peek a boo in between the time the heat sensor engages. Best bet, is to wire a relay to the accesory switch and manually power the fan on and off as soon as you hit stop and go traffic. And lucy, the default install blows hot air from left to right which puts hot in into you intake.....reverse the fan connections so that the air blows from right to left and you always have cool air into your motor.
c. 4" SE slip on mufflers. Yep. the engine can expell heat easier with this larger free flowing pipe. Heat demon started to get worried.
d. Stage I intake. Now were talking more air intake which carries away more heat. Heat demon started to pack his bags.
e. heat shields. These were a pain in the butt to install, and it only helps a bike in motion. The shield does work, but does't help much during stop and go traffic.
f. I took off the egg air cleaner cover. At a stop, the cup effect of the egg air cleaner was basically sucking in hot engine air. I pulled the cover and now at a stop, the bike has an easier time getting cool air. before the cover pull, at a stop, my cover would get hot becuase hot air was being sucked int. with the cover off, the face plate of the intake does not get hot at all at a stop. so I know the heat demon did not like that one either. I'll probally buy a filter sock for ain days, or might just keep my cover in a saddle bag for a while to make sure a light rain won't cause me air intake problems. I know a lot of folks go naked intake, so this one is not a first heard for many. Keep in mind, with the lowers on an ultra, the engine gets hot quck.
g. OK, now this one is not for the squeamish. We needed an easy way to richen up the fuel mixture. 14.7:1 makes for one hot low performing bike. A quick (30 minute) and cheap (6 bucks per pipe, you need two total) is to put an O2 Sensor extender in-between your O2 Sensor and your pipes. This was a dramatic difference and scared my heat demon off for good. Bike runs cooler, more power, better all around performer.
Had my bike for 2 years, wish I would have known about the O2 extenders back then.
yes, it results in a richer fuel mixture. The extenders reduce the exposed surface area of the sensor. I was going to make some from scratch, until I googled and found these. These have a compression washer. They do look like spark plug anti foulers, but the anti foulers I have seen won't work unless you drill out the hole a little. Theres a screen on the Harley O2 sensor that needs be able to pass thru the extender and into the exhaust. on my 07, the screen passes thru this particular extender with no problem. BTW, my bike is a 96, stock cams, no engine work. So if your bike is not stock, your results will vary from mine. I get smooth power thru full range and the bike runs way cooler. Becareful pulling the 02 sensors. disconnect the wires completely, and extend then before turning the o2 sensor or you will run the risk of damaging your cable.
I drive stop and go in NYC and we have heavey traffic. The heat demon used to kick my ***.
one more thing...if you take your bike in to get work done that results in a re-map...you will need to pull these out, otherwise, the remapping will put you back into heat mode....your tune will be adjusted to compensate for the effects of the extender.
Running richer I know is going to cool things but what mileage would expect if I get 37-41 now? Never mind, it wouldn't matter if it worked I could remove them in the fall an if it didn't one trip to town . I guess after his demons were conquered no time to share, only time to ride.
probably what I would do.
