I'm no wrench so when Jamie from Fule moto told me to go with the Adjustable, I said ok. I seem to get the sense that he is in the best interest of my bike and from what I've read fuel moto seems very legit, so I am saying yes to the adjustables based on the fact that by having them they should make the bike run better or allow for a the cam package to work correctly. Should I not get them???? Is there a negitive factor other than the warrentee???
Your bike will generally run the same with stock or adjustable pushrods. Install will be easier with adjustables because you won't have to pull off the rocker covers, saving some install time and hassle. What you pay for the pushrods you'll save in labor charges. Plus if you ever want to swap cams again, you can do it without going through the top end. Only "con" to the adjustables is the possibility that something will loosen up.
