99 flhtcui engine swap ===s&s vs 120r vs jims
S&S make a twin cam 124" that bolts straight into the 99 frame. Get the catalogue at sscycle.com
I had a 1997 king and I can tell you for a fact that this 124 motor in the 99 frame would be bordering on suicide without some serious brakes, suspension upgrades and a stabiliser. A wide rear tyre might be a good idea too.
If you were being sensible you would go for a 98" S&S motor. You will live longer.
I made do with an S&S 107 in my old Evo (replaced by the 111"), but have replaced my swingarm and rear wheel with 2007 parts. I also have a True-Track stabilizer, 13" front rotors and 6-pot calipers. R&R make a nice little 131" billet motor that will bolt right in. Above that the frame needs some serious work to get in the taller rear cylinder.
You can build your stock motor to 120 cu. in. or even larger with flywheels, and boring the cases for larger cylinders. That way you can choose the cams and headwork and still have your stock case numbers. I know two guys with JIMS 120s. From their experiences, and they're both excellent wrenches, JIMS makes great tools. Motors? A little to be desired.
I've looked at bigger engines and I reckon you've covered all options here:
1. pay a specialist to rebuild your motor to whichever size/budget you prefer,
2. build a bigger motor from off-the-shelf parts,
3. buy a ready-built bolt-in motor.
Ain't much left you can do except make your choice! At times like this I find a spreadsheet with detailed options can help, but you should get out there and put in some leg-work. There are engine builders who sponsor HDF you could talk to, and I mean pick up the phone or visit, plus you may have some where you live? But essentially you've asked us an open question, so you need to start reducing the options, not ask us for more!
BlkHillsBagger
Milwaukee Eight (M8)
08-18-2017 01:35 AM
