Codes C1032 - C1095 - C1216
I have a steady ABS light so I ran the diagnostics and got the following codes:
C1032 Front wheel speed sensor circuit open or shorted
C1095 Front brake switch open
C1216 Rear brake switch open
Last night I installed the tour pack wiring harness, could this have anything to do with these codes or is it a trip to the dealer?
Prostar,
Had the same problem before the front wheel sensor has a connector on the left side up front that push locks to the necklace. This 2 conductor wire was getting pinched when you turn the front wheel to left lock with all of the other wires and clutch cable up there. I was able to trace the open conductor form that end of the connector to the other end on the ABS system with normal electrical testing of the conductor. I then opened it up soldered it and relocated it all works fine now.
Also you can go through the process of clearing the code and ride it over 4 mph and test test the brakes to see if it throws the codes again if you think it might be from the tourpak deal. Seems to never fail when you work on one thing something else seems to show up has happened to me on a couple of occasions.
