Progressive shocks
Going for higher performance components is not always the same as more cush for the tush. I had the same experience when I put them on a goldwing when progressive first came out with that series. Yes it did hug the road better, but would also spill your coffee all over the place from your cup holder.
What length shock did you put on? 12"? 11.5? Unload the shocks. My 12" 440s ride like a dream. Very controlled without bouncing, just a gel like compression and release. Much better than my 13 air shocks that came stock.
Do these things come with any instructions? Are they available on the website? In my experience shocks need setting up to suit the actual weight of the rider(s), such as sag, as already mentioned. Sounds as if you don't have enough.
Sounds like a setup challenge. Give us a bit more info and we'll point you in the right direction.
1) Shocks are shipped full soft
2) Standard or heavy duty?
3) What length shock?
4) Weight of the rider?
Here's a quick primer on setting sag.
http://www.progressivesuspension.com/video05.html
