strange noise in neutral
Old 06-08-2011, 06:21 PM
Jace's Avatar
Jace
Jace is offline
Default strange noise in neutral
2011 ultra with 500 miles on it. Just finished up a 100 mile ride and while pulling it into the garage I noticed a weird noise. When the bike is in neutral there is a rather loud rattling/knocking noise coming from the rear area of the engine. If you pull in the clutch lever the noise goes away. If you pull in the clutch lever and shift into gear, the noise also goes away. It's only there when its sitting in neutral.
Old 06-08-2011, 07:04 PM
smithbrl's Avatar
smithbrl
smithbrl is offline
Mine had the same symptoms and the dealer replaced the inner primary bearing.
Old 06-08-2011, 07:11 PM
Jace's Avatar
Jace
Jace is offline
Hmmm, think its safe to ride it until the 1k service then have them fix it at the same time?
Old 06-08-2011, 09:53 PM
smithbrl's Avatar
smithbrl
smithbrl is offline
I would take it in right now. It may break down before you make it to 1k. Then you're screwed.
Old 06-08-2011, 09:56 PM
Cheiron's Avatar
Cheiron
Cheiron is offline
Sounds like the primary output bearing.
Old 06-08-2011, 10:10 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
why all the engine and drive train issues lately on harley twin cam's.
Old 06-08-2011, 10:12 PM
Biggzed's Avatar
Biggzed
Biggzed is online now
By lately, do you mean since 1903?
Zach
Old 06-08-2011, 10:41 PM
SICKBAGGER's Avatar
SICKBAGGER
SICKBAGGER is offline
Yes inner primary bearing seems to be the problem also when you roll the bike forward or backward hot and cold do you hear any clunking like a bearing grinding on a wore spot another tell tale. Not a bad fix you can do it yourself with the manual and just have someone do the bearing removal and repress the new one in.
Old 06-09-2011, 12:38 AM
Keith50's Avatar
Keith50
Keith50 is offline
my bike did the same thing and the main drive gear was going bad and it eat the inner race .... Here is a picture of my inner race.
Old 06-09-2011, 02:25 AM
103 sedona orange's Avatar
103 sedona orange
103 sedona orange is offline
It's a NEW bike take it in & have them check it out!!! Don't wait, you don't want to do anymore damage. Please get back to us & tell us what the problem was.
Quick Reply: strange noise in neutral
