Some thoughts on the front fork air baffle
#31
Received 70,272 Likes
If you decide to install the fork baffle, which BTW is not really visible, you had better run a 1/4-20 tap in the mounting holes first, as they are pretty much clogged up with powder coat. If you decide to mount it as is, you will only get so far and then you will be fighting the install. FWIW.
#32
#33
I have the same bike and the wind coming from the lower tank area drives me crazy, my beard stays in my nose and eyes 100% of my rides. Does the baffles cut down on the lower wind blasting up your chin?
