Compensator replaced now new problem.
I just had the SE compensator installed in my 08 FLHX, under warranty. Now I have a new problem? 500 miles after replacement I started to get a loud grinding sound coming from somewhere "around" the compensator area only when I give the throttle a "blip" on decel. I took it to the dealer for an inspection. I was told that the cush drive is worn out and needs to be replaced, and the sound I was hearing was because of the "slack" in the rear wheel. The service tech showed me that when the bike was sitting on the lift you can grab the rear pulley and rotate it forward and back about a 1/4" of free play. Of course they have to order the parts and was told it would be fine to drive, just dont "blip" the throttle. This kinda worries me should I be concerned ? Any thoughts?
I wouldn't worry too much about it, as long as you take it really easy until it's fixed.
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
General Inquiries:
Phone:
775.331.3789
I have my rear wheel off waiting on a new set of tires. ('08 RG with 25,000+ miles) I also have replaced the compensator w/SE version. I have no grinding noise, and there is no play in the pulley/hub assembly where the rubber cushions are. My .02, it is not the rear wheel. Have they taken the primary cover off and checked ? Who installed the comp.? Good luck.
If you are concerned that you have a loose primary chain, here is an easy way to check. Pull your left passenger footboard off, then make sure the bike is sitting as level as possible. Remove your derby cover (the big round plate on the primary, with 5 screws). Use a flashlight and look at the top of the chain. You have to do this at an angle looking to the left inside the hole. Once you see the chain, using a long thin screwdriver, rod, whatever, flip the chain up and down. If it has no more than approximately 1" slack then its ok. If it is really floppy, like it can hit or nearly hit the top of the housing, then possibly the automatic adjuster is not working right.
