Apply Front Brake at Idle: Bike Runs Rough. Any Ideas?
2011 103" Street Glide.
When idling/stopped in traffic, if I apply the front brake, the RPM's fall just a little and the bike runs rough.
When I release the front brake, while staying in a stopped position, the RPM's return to normal and the bike smooths out.
This does not happen when using the rear brake.
I mentioned this to some other riders and got the standard "They all do that."
Any idea what may cause this condition?
Thanks
Thanks
Welcome to the life of a HD flh* bagger
They all (at least recently) do that.... I don't have the engineering to explain it properly, but it has to do with the engine/frame isolation, and using the front brake directs the vibration into the frame.
On the other hand, once you're rolling, the motor is smooth as silk.
The other choice is a frame mounted motor that is smooth at idle with the brakes on, but vibrates more at speed.
The things to take away are:
1) 'tis normal, don't worry
2) It is better to use just the rear brake (on any bike) at an intersections, with the motor in gear, and the clutch held in
Why do you say this?
In my situation when idling at about 1k rpms, when I grab the front brake the rpms slow.
The reason it does this on my bike is that the front brake is the only brake control that engages the brake lights, the rear brake (pressure) switch hasn't worked since I got the bike. The current drain of all of my brake lights (extra rear brake lights too) puts a load on the charging system. At an idle that electrical load causes the rotor / stator recharge system to draw more current and that current draw slows the motor (at an idle) enough to sense a true change in rpms when the charging system is under load, at an idle.
At idle, there's vibration. Get off the bike (in neutral) and you can see the vibration and shaking through the front tire. When you lock the front brake at a stop, yes, the wheel no longer shakes in relation to the ground, but the vibration with the locked brake has no where to go other than the fork and into the bike.
