Air/Fuel Ratio
Old 06-17-2011, 07:13 AM
iwillfixthem4u's Avatar
iwillfixthem4u
iwillfixthem4u is offline
Originally Posted by bhaxton
An engine cant be constantly ran at stoich. There has to be fuel introduced into the exhaust to light off the cat. Most engine OEM's use a strategy called perturbation. This runs a cycle or two lean, and then a couple rich (around 13.5/1). Dont ask me how I know this. I might have to kill you if I tell you.
Prior to Closed Loop, after CL as close to 14.7 to 1 at constant operating conditions
nvsteve's Avatar
nvsteve
nvsteve is offline
Originally Posted by Harleypingman
Yes, you're all wet. As mkguitar explained, there is no one "ideal" AFR. One of the advantages of EFI is it allows a far greater degree of matching AFR to the required conditions. You need lower AFR (more fuel) running up a hill than you do running down a hill. You need lower AFR accelerating from a dead stop and getting up to interstate cruising speed than you do running at a steady speed on a flat highway.
13:1 is extremely rich for virtually any riding condition; and, if you run that regularly you'll probably have a lot of unburned fuel contaminating the oil impairing the oil's lubrication capability.
Another advantage of EFI is the injectior allows the fuel to mist/atomize faster with the intake air compared to carbs which drips fuel into the intake air. So, for a given rpm and load, EFI allows less fuel to be added than a carb due to EFI's more efficient mixing of fuel with a given volume of intake air.
Carl
All true but isn't the target AF approximately 13:1 for a full throttle roll on?
Old 06-17-2011, 07:15 AM
kingkingking's Avatar
kingkingking
kingkingking is offline
Naw, its lower than that as you roll on (accelerator pump). Once you are at WOT then 13:1 is about where you want to be, but as I said before it isnt that important, 12:1 to 14:1 gives about the same torque and power.
FredAndrews
06-08-2014 06:01 PM
drpcfix
Touring Parts
04-11-2014 10:37 PM
wingman1800
03-24-2011 04:28 PM
goo
03-19-2010 04:49 PM
HDF Tech
General Topics/Tech Tips
06-27-2005 02:41 PM
Quick Reply: Air/Fuel Ratio
