Slip ons vs. full exhaust for 2011 Street Glide
I recently purchased a 2011 Street Glide with the 103 power pack and am trying to decide between slip ons or a full exhaust. I had a 2007 Softail Custom with V&H Big Shots and loved it, but am looking into slip ons to hopefully save money But at the same time I don't want to waste the money on slip ons if I will be replacing them down the road with a full exhaust because I'm not happy with them.
I'm not looking so much at boosting performance but more for sound (the stock pipes just down sound right after having the big shots on my softail). Was told the stock headers on HD was fine for slip ons and to save my money by not going the route of a full exhaust system.
Any suggestions or comments?
Thanks!
Thanks!
Went the slip on route on my 2011 SG with the same 103. You won't get the sound you want with just the slip-ons but it will sound better than stock. Then you can save up, by a new head pipe, a tuner, and some sort of Stage 1 A/C and re-use the slip ons you already have.
At least thats the plan for me.
A true dual system is probably the sound you're after with slipons of your choice. Eliminates the cat and frees up the bike to breath, in-turn will cause you to need a Stage 1 AC upgrade and a tune/tuner.
Slip-ons will improve sound, will not make it run cooler on the leg, and will not require any other modifications.
I went with the Jackpot 4" dyno tuned slip-ons, gutted the stock pipe so it no longer has a CAT, just installed a FM A/C and PCV. Bike runs great and sounds even better! Still a bit of tweaking the map that came preloaded, but I have a 4day weekend this coming weekend. Should be fun! Oh, and if you're just going exhaust, do the cat, see how you like it, then go for some slip-ons. I did em both at the same time and my bike ran wayyy too lean. Hence the new A/C and PCV.
+1 Couldn't have said that better myself! Save your money for the full stage 1. You will be very happy.
