120R realistic hp/tq numbers
#61
#62
new to this forum guys but have been reading it for several months, that being said and being from maine and in the 120r club up here the tuner that you speak of that has the 4 gas system is he from the augusta area? I am going to get my 2012 120r street glide tuned in the next upcoming month after mud season he uses a factory pro dyno , L.A harley uses a dynojet and they have seen a realistic 120-127 out of these 120r engines stock with supermeg and would belive them its about where it should be ,I have gone a different route because I like the look of duals I have altered mine a bit from its original form with roller rockers and 662-2 from t man along with a head mill and 0.30 head gasket. last year the power was smooth all up threw the powerband and it did't stop pulling at 6k with just a se pro tune map so who would you have dyno tune it ? 4 gas or afr tuning ,I have been working on cars for 30 years dealer trained and some harley stuff, seems to me that if cars meet emmissions standards by tuning with afr and o2 sensors then 4 gas might be a little on the overkill side with different camshaft profiles as wild as the 266 is ,or t mans 662-2 or 3
by the way the dealer that I speak of did not sell me the engine or any parts to promote inflated numbers
#63
RoaringRigid (05-10-2019)
#64
#67
#68
I was talking to Jason, and Jamie. They were going to do some research as to a comparable cam to what I have in a gear drive. Looking at the upgrade in the spring at Daytona again. Brooklyn B. What do you see as the advantage with the cam you mention? Have you seen it done? If so any numbers?
#69
