Cigarette lighter
Old 07-12-2011, 05:08 PM
boatsswain's Avatar
boatsswain
boatsswain is offline
3rd Gear
Default Cigarette lighter
I was trying to hard wire my GPS to the back of my cigarette lighter and when i cut and spliced the wires together my i had no power to the lighter. I checked the power outlet fuse and it is good....can someone help me?????
Old 07-12-2011, 05:11 PM
outlaw481's Avatar
outlaw481
outlaw481 is offline
If you have a voltmeter, one side should be 12v DC, other to ground. Maybe you switched the two?
Old 07-12-2011, 05:13 PM
RollaMo's Avatar
RollaMo
RollaMo is offline
Did you have the ignition switch turned on?
That circuit has no power unless the ignition switch is on.
Old 07-12-2011, 05:14 PM
boatsswain's Avatar
boatsswain
3rd Gear
Yes it was on, even started the bike to see if that was the issue
Old 07-12-2011, 05:16 PM
boatsswain's Avatar
boatsswain
3rd Gear
Outlaw,
I checked both sides was not getting power even after i took the wires apart and checked with a volt meter on the wires coming from the battery.
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
IAMSWUTIAMS is offline
When I hooked in my satellite I just pushed the wire on with the terminal. No splicing needed. But I agree with previous posters. You might have polarity switched, or you may not have the key on.
Old 07-12-2011, 05:17 PM
IAMSWUTIAMS
And if it's not the fuse, then you got me.
Old 07-12-2011, 05:20 PM
outlaw481's Avatar
outlaw481
Only other thing I can think of is maybe you pulled the plug loose in the fairing...they don't typically just pull apart, but its possible. Does anything else not work, maybe the ground is bad and moving it around caused it to show...when you checked the hot side, did you check across the wires or to a good frame ground?
Old 07-12-2011, 05:23 PM
boatsswain's Avatar
boatsswain
3rd Gear
The plug on the back of the lighter? If so i checked before i put it back together. I also checked to a good frame ground, read .01 volts. Everything else works
Old 07-12-2011, 05:24 PM
boatsswain's Avatar
boatsswain
3rd Gear
Is there another plug somewhere in the fairing?
Quick Reply: Cigarette lighter
